Hi everyone,
FoxV2 shows my battery temperature as 26.8'C currently.
Energy Stats is showing 40.2'C.
Are they measuring different things?
Energy stats uses the battery value from the openapi, which is actually the bms battery value and tends to be a lot higher than the battery cells temps.
Fox ESS v2 is reporting the correct battery temp known as BMS Cell Temp Low
