h1-6.0-e-g2 discharge settings not working
pyrites
Hoping someone may be able to help with the app settings for discharging back to the grid. Have read the forum and watched videos but nothing is working.
I have managed to successfully set the app to charge the battery from the grid between 12.05am and 6.55am which is working fine but this setting stops working when I try to force discharge between 10pm and 11.59pm.
If anyone has any tips or if I am missing something completely, any help would be most gratefully appreciated. (I have added some pics to show what settings are currently setup based of web info).
I think the shortest answer is to say you cannot mix Force Charge Periods and Scheduler, it's one or the other - scheduler will disable your force time periods.
To do what you want to do, just use the scheduler and disable any force charge slots by setting to 00:00-00:00 - then use the scheduler first entry for your force charge 12.05 and 6.55am and the second entry for your force discharge between 22:-00 and 23:59
