Page 4 of 7
Re: EP11 with heater
Posted: Tue Nov 25, 2025 11:20 am
by WyndStryke
However, the fox ess cloud data is showing the battery temperature as much hotter (which doesn't make much sense as it's 6c outside).
There are actually a variety of different battery temperatures, I suspect the high one is the BMS battery temperature, which is the temperature inside the BMS. This will be noticeably higher than the 'BMS cell temperature low' reading, which is the temperature of the coldest cell. The 'BMS cell temperature low' is the important one as far as the battery heating system is concerned.
Regarding time zone, mine was OK so I've never looked into it, but google suggests that it can be set via the website's plant information screen. Not sure if it is a user level setting or an installer setting.
Posted: Tue Nov 25, 2025 11:30 am
by Arwith
MaterialBarracuda48 wrote: ↑Tue Nov 25, 2025 11:20 am
@Arwith Can you tell me when you put in your support ticket please?
I put one in on the morning of the 20th, and it just sits at processing.
I emailed them on the 20th (
service.uk@fox-ess.com), my first response was on the 21st asking for the inverter SN, and then the next response confirming they updated things was on the 24th
Posted: Tue Nov 25, 2025 11:32 am
by MaterialBarracuda48
Arwith wrote: ↑Tue Nov 25, 2025 11:30 am
Thank you for the update, so my ticket is perhaps stuck.
I went via the app initially, and sent a chase email last night.
Posted: Tue Nov 25, 2025 11:35 am
by Arwith
WyndStryke wrote: ↑Tue Nov 25, 2025 11:20 am
Time zone on the website at least seems correct (though the postcode was wrong, I remember when setting up I could only use numbers on the app...)
- Screenshot 2025-11-25 113312.png (1.92 KiB) Viewed 486513 times
Hopefully it's not something the installer would have to do as mine didn't really know how to set it up, i set up the app myself in the end, though there appears to be not setting in the app for timezone, just country which is set correctly, just weird
Posted: Tue Nov 25, 2025 11:36 am
by Arwith
MaterialBarracuda48 wrote: ↑Tue Nov 25, 2025 11:32 am
Seems the turnaround for email is about 1 working day so hopefully they can help you out there
Posted: Tue Nov 25, 2025 11:40 am
Arwith wrote: ↑Tue Nov 25, 2025 11:36 am
Thanks, let's hope I get a nice quick turnaround.
Posted: Tue Nov 25, 2025 11:48 am
by doubl0dave
Arwith wrote: ↑Tue Nov 25, 2025 11:11 am
In addition to this blocking of charging, I've noticed inconsistencies between the reporting from fox ess cloud and the app. Currently my battery temperature in the app is saying the batteries are 6c, the warmup feature is on and it's climbing by 0.1 every 5 minutes or so so hopefully it is actually heating. However, the fox ess cloud data is showing the battery temperature as much hotter (which doesn't make much sense as it's 6c outside). The app is most likely correct, just odd that there would be different reporting
App temperature is lowest cell temperature which the online version does not show. battemp is actually BMS temperature, not lowest cell. This is the critical temperature for the battery and determines charge characteristics I believe.
Posted: Tue Nov 25, 2025 3:53 pm
by iew100
I've been upgraded to 1.52 master on KH7 and battery BMS firmware 1.009 on my two EP11s. So far, the heater has started every time the lowest cell temperature has reached the 9C trigger point. That has only been during the daytime though. I've set the possible charge from grid option to be anytime in the 24 hour window, though the heater power draw has always been from battery so far. I'm hoping this is a consistent and reliable firmware implementation now.
Posted: Tue Nov 25, 2025 3:59 pm
by Arwith
everything now working for me, did have to contact support again as it seemed the force charging stopped working, but they pointed out that the default setting in the mode scheduler called "force discharge pwr" was 100W and upon increasing it to 8000w (the size of my system) immediately my charging started working so hopefully all my settings are correct now
Posted: Tue Nov 25, 2025 7:07 pm
I now have the 1.009 BMS firmware, so hopefully I can get it to warm up now.
My battery temperature sliders are now also "correct" and no longer -40C to + 50C
My original ticket was lost, so just as well I chased it up yesterday, thanks to those that have provided information.
ETA: Small video captured to show heater in action for those curious. Grid heater set from 00:30 to 05:29, so this was charging from either solar or self-use this morning.
Posted: Wed Dec 17, 2025 12:15 pm
by albie999
I have just logged another ticket with Fox on my system with regard to heating ... as just noticed I was pulling from the grid ... when my battery heater has kicked in. I have had all my firmware updates 2-3 weeks ago by Fox (1.9 etc), and thought the problem had gone away .... so will see what they come back with
Disabled the heating option, and battery is now discharging to cover the house load ... Grrrrrrr
Posted: Wed Dec 17, 2025 7:02 pm
by nrb501
1.011 is now the latest firmware for the EPxx series, interestingly 1.008 & 1.010 are still available so looks like 1.009 was pulled for some reason.
ISTR my system did some weird things with battery heating on 1.009 but not been able to confirm as the weather has been too warm recently (since been updated to 1.011)
Posted: Wed Dec 31, 2025 9:44 am
by hamgeezer
Mine is refusing to even try to heat this morning. Heater on, allowed on grid all day but heating on standby rather than on.
I’m on version 1.009 and not convinced the heating has ever worked. Having it on will sometimes cause overcurrent faults as well which takes the inverter offline entirely. Maybe I have a faulty unit?
Posted: Wed Dec 31, 2025 9:50 am
hamgeezer wrote: ↑Wed Dec 31, 2025 9:44 am
That certainly looks correct, though I would extend the heater higher than 11C.
I would contact Fox Support and get them to investigate, as the heater unit is not high power and shouldn't be taking your system offline.
Ask for firmware update from 1.009 as it was reported above that it may have been pulled due to bugs, and ask about your inverter getting upgrade at same time.
Posted: Thu Jan 01, 2026 8:37 am
by chrisbooth1957
hi does the heater work with the older h1 g1 (h1-5-e) and ep11h
Posted: Thu Jan 01, 2026 11:05 am
chrisbooth1957 wrote: ↑Thu Jan 01, 2026 8:37 am
You know that’s a really good question and as much as i’d like to say the answer must be yes, I don’t know for sure - I haven’t come across that combination (maybe @Will has ?) - if you don’t hear i’d email fox support and ask them directly, and would be grateful if you could post back to confirm.
Posted: Thu Jan 01, 2026 11:46 am
by iew100
My 2 EP11Hs are working well with BMS 1.009. The battery heaters trigger on at 9C and off at 15C (typically over-shoots to 16C). I'm not going to upgrade my FW until the spring unless I get major issues before then. Attached image from Modbus lowest battery cell temperature sensor in Home Assistant.
Posted: Thu Jan 01, 2026 11:59 am
iew100 wrote: ↑Thu Jan 01, 2026 11:46 am
Also with the 1.009 FW version, and my chart looks just the same as yours. I am also going to leave the FW version alone for now, if it is working I am leaving it as is for time being.
I also noted that the battery which normally charges at 23:30 didn't as the battery heater kicked in at this time.
After approx 30mins of heating time, it reached about 10C and then it began to charge from the grid, whilst still heating.
Posted: Thu Jan 01, 2026 1:03 pm
by chrisbooth1957
Dave Foster wrote: ↑Thu Jan 01, 2026 11:05 am
well at first i was told it would work i just needed to get the firmware updated , now foxess tell me the g1 version cant be updated to make the heater work , not a major problem as is in the garage attached to the house . just wanted to check as have conflicting information and the battery documentation says it works with all versions of H1 , but does point out if you mix different versions of the batteries , with and without heaters the heater wont work . to me that implies it should work with the g1 if the only battery
Posted: Fri Jan 02, 2026 4:23 pm
by maccoylton
I have an EP11 running 1.09 connected to a KH10 running Slave 1.01, manager and master 1.58.
My issue is that every so often I am getting the "Over Current" fault, this seems to happen as the battery reaches the lower temperature limit of the heating cycle and the SOC is at or lower then 40%, so the heater need to kick in to heat from the grid. See attached picture for the last two days. Happened around 10:30 am yesterday and then again around 10:03am today.
Fox support upgraded the inverter firmware a few days back, that had no effect, I also saw mention in an earlier post of 1.09 of the battery firmware being pulled and there being a 1.11 version anyone running that or got more info? I've contacted Fox ESS again and wil see what they come back with
Posted: Fri Jan 02, 2026 5:54 pm
by hamgeezer
maccoylton wrote: ↑Fri Jan 02, 2026 4:23 pm
This sounds exactly like my issue. I was upgraded to 1.011 today. Curious to see if it helps.
Posted: Mon Jan 05, 2026 8:00 am
by albie999
I am still having the same problem, with when heater is active, the battery keep stopping to deliver charge to cover house load, and imports from the grid. I have raised this with Fox already ..but I just do not seem to be getting a response
Battery is still on 1.09
I have sent them the graphs below, to show the drop
Posted: Mon Jan 05, 2026 9:03 am
by maccoylton
albie999 wrote: ↑Mon Jan 05, 2026 8:00 am
When this happens what is the SOC of the battery, what is the temperature of the battery, what is you minimum SOC set to, do you have the heated version of the battery and do you have heating turned on, what mode do you have the inverter set to?
Things that might stop battery use include the minimum SOC, the temperature, the mode
Posted: Mon Jan 05, 2026 9:06 am
by albie999
This is an ongoing issue, that I have posted in this thread previously .. and which "Fox" said they had resolved .. but definitely not. Please see below screenshot, showing battery charge is way above the minimum ... also .... my battery is set to heat at 9c ... and it is when this battery warming kicks in .... that this issue happens
Posted: Mon Jan 05, 2026 10:00 am
I am on 1.009, I was going to await a future date and upgrade the battery FW, but today I have asked for the latest.
I have my battery set to charge each night 23:30-05:29 via Home Assistant, working fine. What I observed at 23:30 is the heater kicks in (heater grid charge is set to same as above times only) and the battery didn't take any charge (around 8C) then at 10C it began to charge from the grid. I have not looked at discharge when the heater kicks in, but perhaps I do need to look at the logs.
I asked for a FW upgrade, because this morning after 09:xx it began a heating cycle... now issue was it was using grid power despite a 97% SoC, I was thinking it should use self-power above 55% SoC (or some such value) but clearly wasn't.
