The AC1-G2 series is supplied with a Fox WiFi Datalogging Stick for use with the Fox Cloud. LAN and 4G dataloggers are also available as optional add-ons.
According to some sales blurb, it should have one of these.
Have you got a picture of the offending item?
You might be able to schedule a charge on the screen itself, but it will be clunky to say the least.
That’s what I’ve got. Just a little aerial.
I’ve tried to connect to it via WiFi and it says it’s connected but then isn’t.
Inverter: x1 Fox ESS AC1 G2. 5KW 1ph AC Coupled inverter.
Battery: 2x Fox ESS EP12 11.52KW with heating.
Solar: 12 x Trina PV panels
Inverter: Solis S6-GR1P 3.6k
Ev charger: Easee home 7kw
Might be worth seeing if you can set a charge on the screen manually for tonight, and deal with the problem tomorrow.
Yea I agree. I will try that.
Thanks for all your help
