Re: App currently showing System Offline
The AC1-G2 series is supplied with a Fox WiFi Datalogging Stick for use with the Fox Cloud. LAN and 4G dataloggers are also available as optional add-ons.
According to some sales blurb, it should have one of these.
Have you got a picture of the offending item?
You might be able to schedule a charge on the screen itself, but it will be clunky to say the least.
Antlen wrote: Mon Mar 09, 2026 8:37 pm This is what I constantly get
Ah, just see your new picture.
Will has a video on the setup process, it looks like you may get some information from his video.
Antlen wrote: Mon Mar 09, 2026 8:05 pm As it’s my first day I really wanted to set it to charge overnight at the cheap rate but the app will not let me do anything.
Please help.
And if all else fails :D
An older video from Will, so you could at least program a charge.
That’s what I’ve got. Just a little aerial.
I’ve tried to connect to it via WiFi and it says it’s connected but then isn’t.
Inverter: x1 Fox ESS AC1 G2. 5KW 1ph AC Coupled inverter.
Battery: 2x Fox ESS EP12 11.52KW with heating.
Solar: 12 x Trina PV panels
Inverter: Solis S6-GR1P 3.6k
Ev charger: Easee home 7kw
Might be worth seeing if you can set a charge on the screen manually for tonight, and deal with the problem tomorrow.
Yea I agree. I will try that.
Thanks for all your help
Antlen wrote: Mon Mar 09, 2026 9:10 pm Yea I agree. I will try that.
You are welcome, best of luck with programming a charge in.
