I am currently force discharging my battery but there is only 1.x kw going into the grid and a current load of 3.x kw.
Is this screenshot correct i though the whole 5kw would be exporting
Thanks for your reply.Dave Foster wrote: ↑Tue Sep 09, 2025 8:29 am If you are Force Discharging at 5kW the discharge will be limited by the maximum power of your inverter (i’m assuming this is a 5kW inverter?) - the AC power is firstly used to power the house and any excess will go to export - if your house load is 3.21kW then the 1.91kW being exported is correct.
Can you post your scheduler settings so we can eliminate any errors.Bentleyfamily wrote: ↑Thu Sep 18, 2025 4:55 am Hey guys. I have a issue that is similar to this except that when I do my forced discharge, no discharge happens.
I have my parameters set correctly and triple checked 5000kw/h etc.
At night the house hold uses constant under 1kw/h of electricity but the battery only provides the electricity to the house and not to the grid at all even though it's set up to full discharge to 10%.
Has anyone else had this issue?
Do you have an EV charger or something similar that may be taking power ?Tuckers wrote: ↑Sat Oct 04, 2025 8:08 am Hi All
Please bear with me, I am very new to all of this. We have had a solar system fitted 9 x 500 w panels 6kw Inverter and 10 kw battery. it all seems to be working well. we are with Octopus and charge the battery at night. but we have an issue where the house at 5.30 am after the battery is fully charged starts to discharge and it is saying the house demand is 6 kw we only use between 8kw and 10kw a night but at this time it is saying there is a 6 kw demand ??
Ok if it’s doing that then the system CT clamp is either not connected or has become disabled, sadly more common after an install or the first firmware update is performed - it would be best for you to contact your installer to correct it.
