EP5/EP11 mounting hardware the same?
First time posting, please be gentle!
Looking at upgrade options for my set-up and curious if the wall mounting hardware for the EP5 and EP11 batteries are the same?
Looking at the install docs the only difference seems to be the 3rd mounting bracket for the EP11's
If they are the same would they be a straightforwards swap in and out?
Thanks.
Re: EP5/EP11 mounting hardware the same?
I don't have them in front of me to check, however the brackets are very different sizes (in both directions) - the EP5 has 4 mounting holes, the EP11 have 8 mounting holes, from memory I think they are at very different centres.
Hopefully @Will or an installer with both in stock sees this post so they can answer with more precision.
