Fox system changed from Hv2600 to EQ4300
i have recently upgraded my system to Hybrid 6kw inverter with 24kw EQ4300 battery storage.
Solar system 8kw with Enphase microinverter's untouched.
New system shows "offline" any ideas as to why?
Any help much appreciated
Re: Fox system changed from Hv2600 to EQ4300
Which part is showing as offline, is that what you see on the main ‘house’ page i.e. the system, or is it the battery when looking at the Device page ?
Hi Dave
Thanks for your reply, sorry for the delay in answering.
The offline is showing on the maim page.
Regards
Norman
If you have easy access to the inverter can you check firstly that the display shows a correct battery SoC value (which confirms your battery is ok and working), and secondly if you can check the datalogger red light is flashing approx once per second - if it is flashing rapidly it has disconnected from your wifi (has it ever shown online ?).
Good Morning
Thanks for your reply, SoC is currently 26%, battery voltage 355.3.
WiFi red light is flashing rapidly and I think it has always been since the changeover, does this help you in resolving my problem.
Regards
Norman
