Faulty firmware for the H3-Pro?
After updating the firmware to master: V1.62, manager: V1.34, the FoxESS app and website only display 1/10 of the actual value for the PV current, and the display resolution is reduced.
Can anyone confirm this? A report has been sent to FoxESS Service.
Regards
Klaus
Re: Faulty firmware for the H3-Pro?
Yes Fox have changed the scale in the H3 Pro so that it changes the scale - we don’t know why as it is now different from every other inverter but their latest specificiation confirms the scale change.
There is a PR waiting to be merged and approved, if you are ok to make a few editor changes you can correct the scale https://github.com/nathanmarlor/foxess_modbus/pull/840
Hello Dave,
Thank you for your quick reply. I'm familiar with the linked topic about the changed scales for some parameters.
However, the problem I described is something else. The solar current values are now displayed 10 times smaller, but the resolution hasn't increased, so now only whole amperes are displayed, which is certainly not what's intended. Furthermore, both the FoxESS app and the cloud site itself display values that are 10 times smaller. Thus, the voltage, power, and current values no longer match.
Ahh ok thanks for the clarification, that sounds like a new undesirable feature ;) .. can you keep us updated if you hear something back
