My first post on here! I'm finally getting my FoxESS solar (KH7 inverter) and batteries (2 x EP11H) installed next week, and will be integrating to my HA via modbus. Is there any general view on here about the relative pros and cons of which modbus HA integration to use? I've seen TonyM1958 and Nathanmarlor and wondered if both are equally good? Thanks.
Nathanmarlor - is the most popular as it has a setup wizard built into HA.
Tony's is the most comprehensive and requires managing the config files, but offers fine control over the configuration.
I use Nathan's for every day and Tony's for testing specific changes to the fox modbus addresses.
My scaffolding went up yesterday, exactly the same the kit as yours is in the porch, and the roofers and sparky turn up tomorrow morning. How exciting
I read a problem with the KH series is they don't support "Read/write charge periods" but there are workarounds. I guess we need to find out what they are.
Another problem we have is our next door neighbour got in two weeks ago with a G99 for 7.4kW and that seems to have take up the whole budget for the street! DNO not being helpful at all . Funnily our MP found out about it, and not from me and asked me to contact him. Apparently I am not the first to be knocked by the DNO for a G99 round here, so he is going to find out what is going on.
I'll post what i find out.
My scaffolding is also up for an installation starting on Monday 9th. I did read in the Nathan Marlor's integration features that KH "Read/Write charge periods" is not supported. However I wasn't aware of any potential work-around for that. Have you got a link to more information on that?
Google gave me this via AI with an example HA automation!
https://www.google.com/search?q=foxess+ ... e&ie=UTF-8
I have an automation to write directly to the registers using the service calls.
Detailed here https://github.com/nathanmarlor/foxess_ ... issues/661
I have a KH7 installed with a WiFi dongle to access the Fox Cloud. I'm also a seasoned HA user.
I want to add a Modbus adapter but cannot find any info on the hardware needed and how to physically conect it to the KH7.
Can you advise? (BTW I'm totally ok with the HA side).
Cheers. Steve P
Cheers. Steve P
This should help, https://github.com/nathanmarlor/foxess_ ... ring-Guide plus a list of working adapters listed on the wiki pageTag1956 wrote: ↑Fri Jul 04, 2025 1:55 pm Hi,
Cheers. Steve P
Okay - so I got Nathan Marlor's integration working for my set-up with the Elfin EW11 via Ethernet to Modbus/RS485 Adapter on my KH7 inverter.
Maybe stupidly, I also then tried to set up Tony M's integration to the same Modbus adapter from a separate Home Assistant instance. It didn't work so I uninstalled Tony M's integration.
However my working Nathan Marlor integration connection got broken after this. I've tried rebooting HA and the Elfin EW11 (power cycle).
I'm still getting no data into HA with following error message
"Connection Status changed to Error reading registers. Type: RegisterType.HOLDING; start: 31000; count: 43; slave: 247 from tcp://192.168.50.12:502: Modbus Error: [Input/Output] [Errno 104] Connection reset by peer"
Has anyone got any ideas to resolve?
1) Would rebooting my KH7 inverter help? If so - how do I do that?
2) Do I need to factory reset my EW11 and reconnect?
3) Any other ideas?
TIA
3) Any other ideas?
TIA
Update: the issue seems to have self-corrected after some more Elfin power cycling and HA reboots. Maybe the Modbus buffers just got overwhelmed, though I won't be trying to install both NathanM's and TonyM's modbus integrations together again!
Thanks Dave Forster, the WiKi is great and has helped me identify my solution; 'Elfin EW11 via Ethernet to Modbus/RS485 Adapter on my KH7 inverter.' However, I do not understand the pinout for the KH7. This seems to be the same solution used by 'IEW100'.
Can someone please tell me what the GND, VCC, 485B and 485A connect to on the KH7?
Sorry if this is a real dumb question.
Steve P
Steve P
I scraped a couple of images from the wiki and used it as attached. The circled redlines show the connections.
You should only use the 485A & 485B pins, these are balanced differential pairs and do not need to be connected to ground, it is 485A to 'A' on the adaptor and 485B to 'B'. The VCC is used by Fox internally and it cannot power the adaptor itself, any power for that should be provided locally at the adapter end i.e. 12V power supply, POE etc.. (depending on the adapter you use)
