Inverter temperatures
How accurate are the inverter temps? My F3600 regularly shows greater than 50°C temps but last night at midnight, for instance, it was showing 29 with vane temps of 20 with the inverter off for 5 hours. It was cool last night! Vane temps show approx 6° higher than my thermostat. Can I calibrate/check the temps? Will a false reading impact on inverter performance? I have a fan above the inverter blowing downwards but can't hold the temperature steady.
Re: Inverter temperatures
They're pretty accurate as the sensor is on the inside not the outside, which might explain the difference. Try to keep it under 50c and you'll be fine.
I got a dual-140mm computer fan (powered off USB, from a wall socket adaptor) off amazon for £16, and it was very effective at bringing down my KH7 inverter's temperature. Only draws 4W.
agree, I do the same and it works great.
