Graphical Modbus Tool that I found useful
tony.matthews1
I've seen various references to modpoll (which is great for cross paltform) but wanted something a bit more graphical. Found this tool useful for poking around the modbus data via either LAN or RS485. This screen shot is showing data pulled from my inverter using the LAN with the inverter at 192.168.0.31.
There is a Master and Slave module. The master module is what you want to pull data from the inverter to see what's going on. The communication log shows you what's going on, error codes etc.
You can download it from github: https://github.com/ClassicDIY/ModbusTool
Tony
H1-6.0-E hybrid inverter
6 x HV2600 v2 batteries
16 x JA Solar 405w panels
7 x Tigo TS4-A-O optimisers
dforster
That looks great, I'll give it a try
Will
Thanks for sharing
2 x KH Series Inverters
