Got a couple of questions now the system is running for a week.
For now my H1 is still on a rather old firmware version, which seems to have some issues with manipulating the Time Periods via FoxEss Cloud, but the LAN port still works
Master : 1.44
Slave : 1.02
Manager : 1.39
At the moment I'm getting my FoxEss data in HomeAssistant via the LAN-port on the H1 and the custom integration HA-FoxESS-Modbus, which is working fine for reading data (more or less). The modbus seems to encounter connection losses for shorter and longer periods. Not entirely sure why this is happening though, but it seems not so uncommon when you search the web.
There is a usr-w610 en route so I hope to be able to switch to this solution as I want to be able to control the settings based on different parameters.
My problem lays in the weird power bill calculation in Flanders, Belgium. We are charged on power consumption but also on the use of the grid. This last part has changed and they take now your average peak over 15 minutes in consideration. So basically it comes down to limit your average peak to 2.5 kWh in 15 minutes, which is the strict legally defined minimum. It's a bit more complicated because your yearly use is also a parameter. (In my specific situation I should limit the 15' peak at about 4.2 kWh to avoid a higher bill.)
So the challenge:
Limit the charge current during off peak times (22:00 tot 07:00) to keep below that max peak of 4 kW/15min, but when my PV is active during peak times I want to have the full charging capacity available for charging the battery.
The possibilities are rather limited as there are only 2 Time Periods available
And I don't see a possibility to change the settings via the FoxESS Cloud (i'm a normal end user) to do it manually each morning/evening in the Cloud.
I could go to the inverter and change the setting via the H1, but that's a bit... well yeah you know
