Analysis graphs for inverter
Hi, hope someone can help. I recently had a panel on my solar array replaced and everything is working fine except:-
when using Foxcloud 2.0 app solar data is not shown on the monthly or yearly tabs. All other data i.e. Load,Grid, Charge and discharge. In the key at top of chart Solar is displayed as an option but does not show in chart.
Re: Analysis graphs for inverter
The solar data is a relatively new addition to the V2 app (the V1 app doesn’t have this), when you say you have had a panel replaced - has it been off for a while, have you seen data in the statistics before ?.
There was a graph rendering problem a week or so ago and as the V2 app is still under development it’s always a good idea to update to the very latest app version
Hi, thanks for reply. Yes the system was shut down while panel was replaced. App is the latest version and worked before the shutdown and every other aspect is as before, just won't show the solar aspect of monthly charts which is a shame as I want to monitor daily yields comparatively for a while to understand how system is performing.
Just to add I’m having the same issue on a new install.
Load, Grid and Solar all display fine on the Day graph, but only Solar data appears on the Month or Year graph, despite the key for the graph including all three items.
Hoping someone has some clues of how to fix this🙂
witheyjames wrote: Tue Jun 24, 2025 10:56 am Hi,
I’m guessing this is a solar only inverter as the statistics on the Fox cloud only show these items for Hybrid inverters even when you have a meter fitted - if it is solar only look at home assistant and the cloud integration which will allow you to gather these statistics yourself.
