Export limit
I have two T8G3 inverters installed, one inverter is connected to smartmeter. Allowed feed in power for my connection is 11,1kW. When I set Export power limit 11100 W in inverter settings it works fine, power is limited to 11,1 kw, but only till next morning or inverter restart. After restart Export power settings is always 9600 W. Has anyone solution for this?
Re: Export limit
I would upgrade the firmware and retest. If still an issue report to fox support team
