Public EV Charger API (L-Series)
I've got a setup with H3 inverter, ECS 4300 battery and L-Series EV charger. It's almost a fine setup. What I am aiming for is maximum autonomy of my house. This currently fails because of lack of control over the EV charger. For autonomy I need these requirements to be matched:
  • only charge the car if PV and/or battery can support the load without using the grid
  • never discharge the battery beyond a point, that I'd have to use the grid over night weather; obviously the minimum SOC for charging depends on the remaining daylight hours and weather
To do so I must be able to start and stop EV charging. I also must be able to configure charging current, and maybe even to select number of phases.
Unfortunately I could not find any such API in the OpenAPI documentation. Also it seems that the L-Series doesn't support the open OCPP standard.
Does anyone know if there is any open API one could use for controlling L-Series chargers? If so, could it be added to the OpenAPI documentation? Or is there even planed to add OCPP support the the L-Series, as there is for the A-Series chargers?
Thanks for information.
☀️ 21x 440 kWp = 9.2 kWp
🔋 3x ECS 4300 = 12.4 kWh
⚡ 1x H3-10.0-E
🚗 1x Citroën ë-Berlingo
Re: Public EV Charger API (L-Series)
I run a regular Q&A with the UK fox ess team. I could add this question to them or at least suggest openapi support.
2 x KH & 1 x H1
This would be awesome!
⚡ 1x H3-10.0-E
