setting Max SOC
I want to set the max SOC to 90% in the mode scheduler when force charging overnight. Whenever I do this it still charges to 100%. an I doing something wrong
Re: setting Max SOC
pbdollman wrote: ↑Sun Apr 27, 2025 2:33 pm I want to set the max SOC to 90% in the mode scheduler when force charging overnight. Whenever I do this it still charges to 100%. an I doing something wrong
The MaxSoc setting only restricts the amount of grid charge, solar will always charge the batteries all the way to 100% - if you change your work mode to Feed-in first the batteries won’t be charged.
Just in case you are thinking of a home assistant device, you would be able to do whatever you want with that as you can easily create an automation which reduces the charge current to zero when battery soc reaches 90%.
Re: setting Max SOC
Dave
Thanks for this. How do I go about installing Home assistant?
Paul
FoxCloud 2.0 App
My FoxCloud app has stopped working does anyone know how to fix this
Re: setting Max SOC
likely just need to reboot your internet router and wait 10mins for the fox system to reconnect.
I've also noticed your username is your full email, which is visible to all. I would recommend changing your username to something other than your email.
