Solar iboost water heater with Fox Inverter and EP11
I had existing solar and solar Iboost to heat water installed, now updated with inverter to Fox 6kw and EP11 Battery. I had the Solar iBoost disconnected and when I switched on after it tripped the system. How do `I set up to take solar post filling the battery. Where does CT clamp go related to Battery CT?
Re: Solar iboost water heater with Fox Inverter and EP11
You should set your fox system to feedin mode which is under the quick settings on the v2 app.
Then the iboost will see the export power.
