I would like to use a rs485/usb adapter connected to the comms port pins 1+2 of H3 to access modbus from HA.
But the HA Foxess modbus Integration seems to require only local USB devices to configure. My USB Adapter is connected on another linux host in the LAN.
Any idea how I can use it remotely from HA? Like ser2net or similar?
Thx
    				    					Fox ESS hybrid inverter H3-10.0-E 10kW
18x440W (2 strings)
EK11 storage 10.36 kWh
HomeAssistant
    				    			18x440W (2 strings)
HomeAssistant
UPDATE:
sorry, I just realized there are indeed LAN options to configure, like "Direct LAN connection" or "Ethernet to Modbus/RS485 adapter".
But somehow none of them work for me (using ser2net on the remote host).
I get:
Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 8 bytes (0 received)
I assume I have some cabling issue. I need to check further, and will update here...
I get:
18x440W (2 strings)
HomeAssistant
    				    			18x440W (2 strings)
HomeAssistant
UPDATE2:
Finally it works. ser2net was NOT working.
I used "mbusd" on the remote Linux host to relay it as "modbus TCP".
Now the nathanmarlor/foxess_modbus integration detects it properly.
18x440W (2 strings)
HomeAssistant
    				    			18x440W (2 strings)
HomeAssistant
