Hello from Dorset
We have just paid the deposit on a 17 panel solar system with Thermohome Solar (based near Exeter Airport)
17 x 445 Watt Panels
1 x H1-5.0-E (Fox ESS)
1 x FE-HV-ECS-2900-4A2C, 1 x FE-HV-ECM-2900-4A2C (Fox ESS)
We have a Polestar 2 single motor long range with a 82kWh battery. Annual use is about 7500kWh and the OpenSolar quit estimates the panels and battery will generate over 90% of our usage.
We are looking forward to seeing how the Fox inverter and Cube battery system performs.
Already on the Octopus Intelligent Go tariff with 7p/ kWh overnight electricity. Will probably join the Outgoing 15p/kWh export tariff too.
Let’s see how the install goes. :geek:
Re: Hello from Dorset
good luck, post photos when all installed.
