USB Connector brand
I have a Fox AC1 battery inverter. I want to integrate it with Home Assistant rather than the Fox wifi dongle. To do this using up the mod bus pins and an Elfin W11 Wi-Fi device.
There’s no mains socked close to the inverter so for the time being I’m powering the Elfin from a power adapter and extension cable.
The Elfin would make the wifi dongle redundant so I’m thinking off hijacking the 5V from the USB to power the Elfin.
To maintain the IP rating I’d like the same type of connector the dongle uses but there is no branding I can see. It doesn’t seem to be from the industrial manufactures I’m aware of (Amphenol, Bulgin, TE).
Does anyone know the brand of connector? So that I can order a wireable equivalent?
Re: USB Connector brand
I would run the network cable from the inverter to an indoor or IP rated box with mains power. I wouldn't run it off the USB port.
Morning,
Sorry, I didn't read your suggestion until after I'd done what I planned. But I did take a punt on something that looked similar and got lucky!
Turns out the USB connector is compatible with Amphenol MRU series. Specifically the Amphenol part number is MRUAM214000 and they can be ordered from RS.
I've soldered mine up and had it connected for a few months now and all seems fine. Its probably an abuse of the USB 5v supply but it was running a Wifi device before and its running a Wifi device now. So, meh.
