EPS sensor.foxess_eps_rpower wrong
Hello ... I did a few versions of software updates today and sensor.foxess_eps_rpower is not working correctly. It works when I'm in self-use mode but when pulling from the grid it drops to zero. Meanwhile sensor.foxess_eps_rcurrent is still working fine (showing 14.7A for example when eps power shows 0 kW.
My whole house load is on EPS output, so that's why I use this number a lot.
Can you pass that along to the Fox folks and get it fixed?
KH 10.5
24 x 480w PV panels N/S
8x ECS4800v2
W4 Datalogger
Home Assistant via Modbus
Sussex
Re: EPS sensor.foxess_eps_rpower wrong
UK_KH_User123 wrote: ↑Wed Feb 12, 2025 11:45 pm Hello ... I did a few versions of software updates today and sensor.foxess_eps_rpower is not working correctly. It works when I'm in self-use mode but when pulling from the grid it drops to zero. Meanwhile sensor.foxess_eps_rcurrent is still working fine (showing 14.7A for example when eps power shows 0 kW.
Will is aware of this one, it seems to occur when you are running the EPS in UPS mode - he has reported it to Fox (last week), when he next checks in hopefully he can update
Thanks Dave! Yes, that's how I run it too. Not a big deal. Using "load_power" instead may give the same numbers in my use case anyway.
KH 10.5
8x ECS4800v2
W4 Datalogger
Sussex
