Apologies -another newbie question! I've wired in my USR-W610 to my H1 Inverter and can log in and ping the converter OK and I set a username and password so I can login via its IP address using a browser from my windows pc. HA is running OK on a Raspberry pi for lots of other stuff. Then I followed Will Eccles excellent You tube video but I don't get any values in my HA Overview page ( see screenshot attached). I think I messed up by not adding the IP address to the secrets file correctly . Presumably this the IP address of the USR-W610, 192.168.1.229 in my case? Do I need to put the USR-W610 username and password in to? If so what's the format?
I did search around the forum and google for an answer but without success. Sorry yaml etc is rather new to me. I've attached excerpts from my secrets & config files below. Any ideas gratefully received. Thanks!
