energy consumption grid purchase figures
The figures for grid purchase on my Fox Cloud app 2.0 are consistently lower than those shown on my energy suppliers app and my smart meter. Anyone else had this or explain why. Thanks
Re: energy consumption grid purchase figures
Which inverter model do you have ?, and can you provide some examples of the differences please
We have a H1/AC1 inverter
grid consumption per supplier Nov 201.62 Dec 304.8 Jan 193.74
grid consumption per supplier Nov 189.3 Dec 288.3 Jan 180.2
the daily difference in Jan is an average of .5 Kw/h
Iggsy469 wrote: ↑Sat Feb 01, 2025 8:07 pm We have a H1/AC1 inverter
Ok, thanks - the inverter uses a CT clamp to measure loads and usage, the CT clamp is typically between 2% - 5% accurate being worse at low loads, it isn't a replacement for the smart meter which can also take power factor into account - the readings from Fox will not be as accurate as your smart meter.
Looking at your usage your daily use is ~6kW (a base load of 262 watt/hours) which is low - you may be able to improve the accuracy by re-positioning the CT clamp away from any other magnetic sources or other CT clamps and/or shortening the length of cable between the clamp and the inverter but you are still within the 5% tolerance.
Optionally you can replace the CT clamp with a meter (Chint or Eastron), they are more difficult to install but are more accurate albeit nothing will be as accurate as the smart meter.
I am also finding this and I have a smart meter so have been assured by my energy provider that the ESB readings are accurate. My smart meter electricity readings are about 3 times higher than my fox readings.
