Different Size Batteries
WillyM
I have a 10 panel system with a H1-5.0-E-G2 inverter and a single EP5 battery installed but the battery capacity isn't sufficient for my needs. I understand I can get additional batteries but do they have to be the same model? Could I, for example, add an EP11-H to my system? Everything is installed outside hence the heating version.
WyndStryke
No, you have to have 4 of the same. So 4x EP5 (non-heated), or alternatively you could ebay the EP5 and then get up to 4x EP11-H or 4x EP5-H.
If you were to add an EP5-H alongside your existing EP5, you would not be able to use the heating functionality because it is only enabled when all the connected batteries have heaters.
Will
WyndStryke wrote: Thu Jan 23, 2025 1:56 pm No, you have to have 4 of the same. So 4x EP5 (non-heated), or alternatively you could ebay the EP5 and then get up to 4x EP11-H or 4x EP5-H.
Spot on, this is correct advice. If your current EP5 is working without a heater ok then scaling with more isn't a bad idea either but no you can't mix EP sizes.
2 x KH Series Inverters
Gimo74
What if the inverter has 2 battery inputs, like the H3-Pro?
Could I, for example, insert
an Ep11 under the first input and
an Ep5 under the second?
Gimo74 wrote: Wed May 07, 2025 10:37 am What if the inverter has 2 battery inputs, like the H3-Pro?
Fox say you should have matching battery stacks on the H3 Pro, although a few people have tested it using different battery models - however the capacity must be the same on each input.
