Hi, the entiities being reported from my solar inverter and battery invert have frozen, how do I kick start them to resume?
Home Assistant entities frozen
- solarschols
Are you on the Cloud version of the integration ? - if so has anything changed (particularly have you changed your api_key).
A restart on your home assistant is usually the first port of call, under Developers Tools, click the 'RESTART' button on the right hand side and choose the 'Restart Home Assistant' option.
If it still doesn't work can you paste any error logs that are showing in your logs (Settings, System, Logs)
- solarschols
Thanks for reply, nothing had changed. I performed a full reboot, system has come back online. Will keep that in mind if it happens again.
Solarschols
FoxESS 3.6k Dual Tracker Inverter
FoxESS 3.7kW AC charger
FoxESS 8.64kWh Battery
2x8 solar panels 4kW arranged East/West
Panasonic Heatpump - 3 wall units
Kia e-Niro fully electric
Home Assistant
Emoncms - OpenEnergyMonitor
Home Assistant
