Re: Trouble setting discharge and charge
Amandyadams
We have a h1-6-0-e-g2 inverter and 2 ecs4100 batteries.
With 9 panels...hoped for 10 but couldn't fit on our roof spaces.
We have managed to use the mode schedule to charge to100% overnight2-5am (on octopus flux) and if we want have worked out how to discharge between 4 and 7pm althought ATM we are not generating enough to do that.
We want to set it so that if by 3pm the battery has gone below 50% it will top up from the grid. I thought I'd done it but I have noticed that even tho I set the min soc to 15% max soc to 50% thinking it would charge if below 50%, it's charging from the grid even if battery is at 70%. I'm totally frustrated as I hate not understanding things. Anyone able to suggest a fix. ?? Thank you in advance!!
Will
Looks like you want more advanced automation, only way I can really think of doing this is using home assistant with a modbus integration but that is fairly technical.
2 x KH Series Inverters
