Adding new batteries
Does anyone have a step by step guide or a link to a video for adding more HV2600 batteries to an existing install?
Solar panels: 10 x JA 405w
Inverter : Fox ESS H1 3.7E
Batteries: 2 x HV2600
iBoost
MyEnergi Zappi V2
Electric car
Re: Adding new batteries
Power everything down (solar DC, AC, batteries) then isolate the batteries. (See video on this group for how to do all this).
I then disconnected the earth and power from the BMS to the top battery, added the new bracket, and refitted the BMS. Then insert new battery and connect earths and power (basically matching what your installer has done).
There’s a dial on the BMS which you point to numberOfBatteries - 2. If you have 2 batteries now it’ll probably be at 0, so after 2 more batteries you’ll want 2.
Double check everything and reverse the switching things off procedure again from video on this group.
Then set the batteries to force charge for a few nights to let the BMS settle.
