Hello all,
I added a third HV2600 ver D battery to my system today. Everything seems to have gone smoothly, I waited until the system said that it was 50% charged ( it was actually 51% by the time I got up onto the loft. I then added the new battery and once it restarted the system was showing 52% charged. The green leds on the front of each battery were flashing as they should and the inverter was showing 'normal' once it had finished booting up and it had charged to 82% before the sun went down. Going to force charge it tonight to help balance it all.
My question is where can I find, in the app or on the foxcloud website, how many batteries or how much kwh are on my system to check that the new battery is recognised?
Any help is much appreciated.
Added a new battery - Need some reassurance
You can’t see the battery capacity in the app, but you can see how many batteries are fitted by looking at battery volts which would be around the 162v range.
