Light/Dark Mode
Quick links
Unanswered topics
Active topics
Search
FAQ
Light/Dark Mode
Login
Login
Username:
Password:
Register
Inverter F3600 + meter DDSU666 wiring and configuration
Skip to content
FoxESS
Home
General Help
Customer/End User Help
Navigation menu
Advanced search
Topic tools
Print view
Search
Search:
3 posts • Page
1
of
1
repsons
Fri Oct 18, 2024 10:40 am
Hi! I have single phase system: Inverter F3600, bought a meter Chint DDSU666.
Wired, wire UTP, 8m long:
DDSU666 pin23 --> F3600 pin3
DDSU666 pin24 --> F3600 pin4
After enabling /meter/ in the inverters config, returns "meter error" (before shows Pex=0, it means, no meter readings).
What's the matter?
Fri Oct 18, 2024 12:17 pm
Re: Inverter F3600 + meter DDSU666 wiring and configuration
Just to double check you, you said pins 23, 24 - I think you meant 24(A) & 25(B) where 24 goes to pin 4 on the meter and pin 25 goes to pin 3
You need to make sure you have set the meter up as modbus, id 001 and 9600, N, 8, 1
repsons
Sat Oct 19, 2024 7:21 pm
Thank you very much Dave, it worked!! Main problem was to set right protocol. Regarding to wiring, you are right, too. Thanks!
Topic tools
Print view
Display and sorting options
Display:
All posts
1 day
7 days
2 weeks
1 month
3 months
6 months
1 year
Sort by:
Author
Post time
Subject
Direction:
Ascending
Descending
3 posts • Page
1
of
1
Jump to
Recommended Suppliers
General Help
↳ Pre-sales Questions
↳ Customer/End User Help
↳ Mobile App Help
↳ Video Guides
↳ General Chat
↳ Feature Requests
International Users
↳ Australian
↳ French
↳ German
↳ Italian
↳ Belgium/Netherlands
Hardware
↳ Inverter Hardware
↳ Solar Only
↳ Hybrid (Solar + Battery)
↳ AC (Battery Only Inverters)
↳ Parallel Systems
↳ All-In-One Systems
↳ Battery Hardware
↳ HV2600
↳ Energy Cube (ECS/EQ)
↳ Mira HV25
↳ EP3 / EP5 / EP11
↳ G-Max Grid Scale
↳ Firmware
↳ Manuals and Datasheets
↳ Virtual Power Plant (VPP)
↳ Capture Energy
↳ Axle Energy
↳ Home Assistant
↳ Automation Ideas
↳ Dashboards
↳ Sensors
↳ CAN bus (Advanced Users)
↳ Energy Stats App
↳ Predbat
↳ OpenAPI
Useful Links
↳ Facebook Group
