H1 G2 3.7 - Maximum PV1 string power
ips38
Quite new to this.
I just had a look at the datasheet and it appears to say that although max PV input is 5500W, its over two strings. 2750W each.
The PV are all connected to PV1. Often generating >3.6kW . For instance today it got to 3.79kW on the App2.0 / FOX cloud graph. During August and a few days in September although not great weather in UK NW, there were many instances of full sun and on that 3.7kW ball park (even 4-ishkW reported on the actual panels on the 5 minutes window on App2.0).
Is this an issue?
Also, it shows flattened, which might suggest some clipping?!
Thanks a lot
H1 G2 3.7 / 1xEP11 / 11x405W (4455W) / South facing.
August 2024 install. UK NW
