alias: Charge Reduction
description: ""
trigger:
- platform: time_pattern
minutes: /1
condition:
- condition: or
conditions:
- condition: numeric_state
entity_id: sensor.battery_soc
below: 90
above: 93
action:
- if:
above: 92
then:
- if:
entity_id: sensor.max_charge_current
above: 10
then:
- service: number.set_value
data:
value: 4
target:
- service: logbook.log
data:
message: Setting Max Charge to 4A
else:
- if:
below: 90
then:
- if:
below: 10
then:
data:
value: "35"
target:
data:
message: Setting Max Charge to 35A
mode: single
Whilst this will slow down the final 6% of charging the battery it helps to maintain the battery balance by giving the batteries more time to top balance.
In home assistant go to Settings, Automations & Scenes and click the blue button in the bottom corner that says 'CREATE AUTOMATION' , select 'Create new automation', then click the three dots in the top right corner of the window and choose 'Edit in Yaml'
Copy the code above into the new automation overwriting what is there, then click 'Save'
This automation will be called 'Charge Reduction' and once saved will start to work the next time your battery SoC goes over 93%
