Ac1 inverter data to Home Assistant help
solarschols
HI, I recently purchased an FoxEss AC1-3.7-E-G2 inverter. This is currently connected to the FoxEss cloud via a FoxEss datalogger type W4 (photo 3) . I have Home Assistant set up to receive the battery inverter data but I find this being received much to slow.
I know that there are several other ways of getting the data into home assistant quicker but I'm a completely lost.
I went to the store where the FoxEss inverter is on display and see that (under a small panel cover) (photo 1) there are both COM and DRM ports however the small panel cover (photo 2) on my inverter has marked DRM, parallel 1 and parallel 2 I haven't removed the panel cover yet (very tight access). If these ports are accessable can I use them or do I need to unplug the datalogger and connect from there to home assistant if so using what cable. I have a ethernet hub close by.
There is talk in other literature about a "usr-w610 rs485 to lan adapter" if I need this where does it plug into?
Solarschols
FoxESS 3.6k Dual Tracker Inverter
FoxESS 3.7kW AC charger
FoxESS 8.64kWh Battery
2x8 solar panels 4kW arranged East/West
Panasonic Heatpump - 3 wall units
Kia e-Niro fully electric
Home Assistant
Emoncms - OpenEnergyMonitor
Hi, as you say the cloud is based on a 5 minute resolution which is the data interval that the datalogger 'dongle' sends the data to the cloud.
The DRM/Parallel ports are actually CANbus ports but they are specific to the inverter functions such as BMS / parallel operation (when linked to multiple inverters).
What you need to connect is an RS485 cable to the Meter/CT connector - I wouldn't recommend the USRW610 it's very slow, for wifi look at the Elfin EW11 but there are also USB RS485 adapters that work well.
There is a link here https://github.com/nathanmarlor/foxess_modbusto the RS485 home assistant integration and this link takes you to the wiki page which has wiring guides https://github.com/nathanmarlor/foxess_ ... ring-Guide and information on adapters it has been tested with.
solarschols
Dave thanks for information.
A little above my pay grade, I thought it would be a simple plugin and bob's your uncle and away we go.
Will have to think about this and see if I can get someone to help with this.
Regards
Solarschols
Home Assistant
solarschols wrote: Wed Sep 04, 2024 9:38 am Dave thanks for information.
Regards
It is a bit fiddly and often the CT wires that already run to it will break whilst you are doing it - but if you go carefully and stay calm, it's not as bad as it sounds.
A lot of the installers will be asked for this when they are fitting the system, so yours might be able to help - but if you have someone with electrical experience it should be a doddle for them.
solarschols
I see what i can do when I get back from holidays.
Regards
Solarschols
Home Assistant
Themykeyreturns
Hey Solarschols - seems like you are just slightly further ahead in the same journey as me with the integration for home assistant. Did you end up having a go at the modbus integration when you got back from holidays? Im interested to know how you got on if you did.
