Fox2.0 Octopus detail
Hi, seeing the Octopus tab in the 2.0 app - Can someone tell me what number is expected in the top field. I have the API key for field 2, but for field 1 I have tried MPAN and SN, but neither work. Any suggestions that have worked here? Thanks. (Info says Company Number).
I can't help with the app question, but Will has done a video of it's use via the Fox website which might help https://www.youtube.com/watch?v=7kyAh8DDx8c
I'm not a used of it but i've picked up some of the headlines - and just one word of warning about using it, Agile Integration, Schedules and Charge Times are mutually exclusive.
If you set up the Agile integration it will replace any schedules you have already configured and once enabled any schedules or Charge Times you have set will be ignored.
