Good improvements to charge/discharge issue reported by users running this new firmware version.
Hi Will - how do I determine what firmware version I have currently on my EnergyCube?
My installer says it is up to date but I am seeing having intermittent weird behaviour - no charging/discharging, sometimes charging from grid outside of force charge windows, etc, with no discernable correlation to temperature/SOC/etc - so I would like to know for sure!
Thanks,
Jim
Thanks,
Jim
15 x Evolution Elite 400w
H1-5.0-E inverter
Fox ESS Energy Cube (16kWh)
H1-5.0-E inverter
Users have reported that this firmware update has caused the modbus via the lan port to stop working. Is there someone that got it working back again (without downgrading the firmware if at all possible)?
Seems like you need to move to a Modbus RTU to TCP converter rather than direct LAN connection
