Hello
I have a Gen 3 Tesla Wall Charger that I would like the live data sent through to my FoxCloud App when charging the car and was wondering if anyone knew how this can be done?
My inverters are 2 x Fox ESS G5000-F2 that connect to a 13.2kW PV system and I can view live data on either the FoxCloud Apps or via the FoxCloud website so that component is already setup.
Unsure if the Gen 3 wall charger requires some type of dongle (doesn't appear so) or whether it tethers to the FoxESS dataloggers WIFI or perhaps it cant be done at all...
Thanks in advance
Regards
David Ludlam
Tesla Wall Charger (Gen 3) WIFI/Inverter/Datalogger connection.
I'm not aware of any local integration that allows Tesla data to be incorporated into the Fox cloud data.
If you are slightly technically minded the best way to do this is to set up a home assistant (a small micro computer) - which can interface to the Fox cloud and there is a Tesla integration as well which would combine it all in a single screen (or dashboard as home assistant calls it).
