help understanding app overview page
Hi All
Time of reading is 19:52, my app reading : load 11kw, PV 54w and grid 69w. I am a little confused,, if the house load is only 0.11kw, why am I drawing 69w from the grid. Confused.com
Also how do I get a total export read from this app, does this feature exist?
Appreciate your help.
Judy
Re: help understanding app overview page
Hi, which app are you using, is it the V1 app (blue background) or the V2 app (black background) ?
The data screen is a snapshot taken every 5 minutes so not a real time view, and when larger appliances turn on and off you sometimes see strange numbers (sampling errors) which will correct after the next data snapshot is taken 5 minutes later.
But all of those measurements you mention are very small, the inverter is grid tied and takes a small sample of power off the grid usually around 15W to synchronise when it is not exporting but I suspect what you are seeing is just a sampling error.
Hi Dave
V2 app. I appreciate your explanation.
Thank you
Judy
Ok, if it’s the V2 app from the ‘plant’ page (the picture of the house), swipe left and you will see this screen -
You can see the export total for the Day, Month or Year by changing the selection.
I explain the grid use here in this video, ignore most of it as it's out of date but the response and background grid draw is still accurate.
