I have a hybrid H1-5-E with 15 405W solar panels, 2 MIRA-HV25 battery packs and a MIRA-BMS.
I am trying to connect up the MODBUS on the Meter/CT/RS485 connector.
I have checked the Device ID.
When I send a MODBUS request the response is a single byte.
I have tried different settings but to no avail.
Firmware versions:
Master 1.48
Slave 1.02
Manager 1.45
Any help would be greatly appreciated.
Thanks.
MODBUS on H1-5.0-E
A few things to look at, have you been using modbus direct over LAN?, if you have you must disable the ethernet port for the RS485 to respond.
How are you sending the modbus request, using modpoll.exe ? and if so what is the command and register location you are writing to.
If you are using modpoll.exe this request should get you a response for the PV registers
modpoll.exe -m tcp -p 502 -a 247 -t 3 -0 -1 -c 3 -r 11000 192.168.xxx.xxx (put in your TCP IP address here and assumes you have set you slave ID in the inverter settings to 247)
Thanks Dave,
I am using MODBUS RTU connecting to pins 3 & 4 as my inverter does not have an ethernet port but does have the ability to set DHCP or IP address.
I have tried different programs including modpoll.exe
modpoll -m rtu -a 247 -t 3 -c3 -r 11000 -b 9600 -p none COM5
ok, for what it's worth be sure that your DHCP is set to disabled and I think you said you had checked the slave ID but whilst you are in the menu double check it's set to 247.
Your modbus command looks correct, i'm quite surprised it doesn't respond ?
Pins 3 (485B) & 4 (485A) are the correct pins and should be connected straight through A>A and B>B
What adaptor are you using in between the inverter and your host computer, are there any settings in there ?
Looking at your inverter firmware, that is quite old, but that shouldn't be causing you a problem with this.
Hi Dave,
I'm using a Waveshare USB to RS485(B) as listed on Nathanmalor GIThub site.
I'll keep trying as I'm sure there's a setting I need to change that I've missed.
Once I get it working I plan to connect it to HA. I even might create my own monitor as I have various micro controllers lying around not doing much.
Kind Regards,
Kind Regards,
Contact fox support and they'll upgrade your firmware for you over the air.
2 x KH Series Inverters
I went through all the settings on the inverter and checked the wiring.
I re-ran Modpoll but still it didn't work and then suddenly just before I was going to give up it worked.
Great News! I can now use my test platform to check everything works in HA before I purchase dedicated hardware to run HA.
Kind Regards,
Kind Regards,
Great to hear you got it working!
Keep us posted!
