Battery draining overnight
I've recently had a system installed and find that the battery discharges slowly overnight until it reaches a couple of % below the minimum charge (set at 20%), even though there is only very minimal use of electricity. Is that to be expected or is it something to worry about?
It's perfectly normal to do that, the inverter and batteries takes some power to stay operational and ready. This is taken from the DC side rather than use the grid (DC = batteries or solar during the day). The amount of power it uses depends on the inverter and the number of batteries you have but typically in the range 30 to 100Wh.
What battery capacity do you have? What percentage of charge is in the battery when you go to bed?
Trying to understand if you are losing a lot of charge overnight or some charge (which as Dave points out is normal).
Fox BMS v2
Fox ESS Hybrid Inverter 3.7
Mira HV25 x5
Trina solar panels x8
Ohme Pro EV charger
Skoda Enyaq
Mira HV25 x5
Ohme Pro EV charger
Skoda Enyaq
That sounds about right,
To do some quick maths if you assume 45% at midnight and 20% at 6am, then 25% of (2*2.38) = 1.19kWh for 6 hours or 198 watts per hour so you obviously have quite a low house base load (fridges, clocks, chargers etc..)
