Hi, I've just got my PV system installed yesterday (after 9 months wait!!), and I'm already desperate for more stats now the sun has come out today!
I've been looking at the various methods, and I'm a little reluctant to use LAN as it seems a firmware update could very likely break it.
So looking at wiring in the modbus, I'm just wondering how youve actually made the physical connection. Have you bought a connector and soldered wires to it, or have you just jabbed wires into the holes?! I haven't had a chance to get in the loft and look at whats there, but from my understanding there is already something using the COM port, so how to I make my connections alongside it?
Nik
Physical connection to the Inverter
> add your cabling to the screw terminals for Pins 3 and 4 for RS485
This part I understand and can easily do. I’ve dismantled the RS485 connector previously. But can you explain what is on the other end of these wires and where does that go to?
Many thanks!!
Many thanks!!
Fox ESS KH10.5 Hybrid inverter
15 x Longi 550W solar (8.25 kw)
Fox ESS Cube 3 * 4.7kw (14.1 kw)
You need something like this https://amzn.to/3psSByE to convert RS485 to a usb or there are RS485 to wifi adapters. There is some more info in the Home Assistant threads.
I have the above connected to a Raspberry Pi2 running Home Assistant and it works great.
See the links on the right here: https://github.com/nathanmarlor/foxess_modbus/wiki
