No PV generation when force charging.
Sloanyd
Hi Everyone.
Does anyone know if Fox has fixed the problem where PV generation appears to be stopped when force charging from grid in schedule mode?
I am on Octopus agile tariff and sometimes give my battery a boost before 4pm if PV generation has been low.
Is there any way to go back to the two slot charging time as it used to work in the mode, I have deleted all schedules but get an error.
Thank you for any replies.
Darren
I am on app version 2.0.3
If you are using the schedules when you force charge PV power is disabled, I am told you can get round it by raising ‘minsoc on grid’ to 100% and the PV will then be used but it’s a fiddle.
It’s best to use the old charge periods for this, I think at the moment the new app isn’t working (don’t forget it’s a beta) - but if you use Energy Stats or the old ‘V1’ app you can still use the charge periods which do allow PV generation to be used.
Sloanyd
Brilliant! thank you Dave
