Removing meter/CT clamp for modbus?
jbee
I'm looking for a bit of assistance please. I have a modbus to connect into the inverter (H1-5.0.E), but there's a cable coming out of the rs485 port, leading to a CT on the cable linking into the meter.
Assuming they are using the same port, is it possible/sensible to remove the existing cable and replace with the modbus instead?
Thanks for your help.
calum
FoxESS Modbus HA Integration
Contact Fox here
jbee
Thanks, this is really helpful!
jbee
I've done everything as per instructions, modbus all wired up. Except for the usb. I cannot work out how to get the cap/cover off to access the usb port on the inverter. It's a slot that says M20 x 1.5, looks like you could put a coin in and turn it.
When I try and turn it, nothing is moving and I feel like I could be damaging it.
Is there a special tool or a knack to open this?
Thanks.
It used to be a rubber cap, so it should prise out with a bit of gentle teasing.
