Is anyone else having issues following the maintenance work on Foxesscloud over the weekend?
Both web/app are showing pretty much zero energy use since around 4:41 this morning. Also, the battery status is blank (0%, 0 power, 0 voltage).
The battery/inverter appear to be working fine.
So, I'm guessing that either there is an issue with the cloud service or my inverter has gone offline and is not sending data to the cloud. If the latter, how do I check/resolve that?
edit: looking at the datalogger on foxesscloud shows that it has signal and has a green tick by the status, so I'm guessing the problem isn't at my end.
Thanks,
Graham
Ongoing issues following maintenance over the weekend?
Mine too!
MrTim wrote: Mon Dec 11, 2023 12:05 pm Mine now seems to have just updated in the last 8 minutes. Everything appears back to normal.
FoxESS AC-1-5.0-E Inverter
FoxESS ECS Series: 1x FoxESS CM2900, 6x CS2900 batteries
Lux Hybrid 3.6K Inverter
9x 320W JA Solar panels
Tesla
Octopus Intelligent Go
Tesla
Both app and website are virtually unreachable. I get "error 5XX" when trying to use website and timeout after timeout error with the app.
Getting tired of second rate service from FoxESS. I've had my system 2 years and with the recent firmware update I was finally satisfied I had a great system until they broke the app and website with the recent update,
With Christmas knocking at the door I suppose I can look forward to another 2-3 weeks of flaky-at-best performance.
I'm back to thinking as I did after my installation was completed and I was given no instruction whatsoever. My installer even threw the supplied instructions out with the rubbish.
In a nutshell, "I WISH I'D GONE TESLA!"
I haven't checked in the last few days but, on logging in today on the phone app, again I'm having trouble connecting. "Failed to coonect to Foxess......etc"
Is anyone else having the same problem?
Just tried with the Fox app and Foxcloud2 both working ok, if you are using energy stats make sure you have the latest update.
