System has just been commissioned today. If I look at the app I can see the batteries are at 38% capacity in the picture of a house screen. Is there anywhere that displays the full capacity in KWh? I have five HV25s so I was expecting to find a screen that says approx 12Kwh usable storage capacity of which you have 38% remaining. Is that possible?
Thank you.
iOS App, where do you view battery capacity? Newbie question!
No in the Foxess app there isn't a screen that shows you usable capacity just the SoC and you have to do the calculation yourself.Dad wrote: Mon Nov 27, 2023 7:30 pm System has just been commissioned today. If I look at the app I can see the batteries are at 38% capacity in the picture of a house screen. Is there anywhere that displays the full capacity in KWh? I have five HV25s so I was expecting to find a screen that says approx 12Kwh usable storage capacity of which you have 38% remaining. Is that possible?
Thank you.
The better app to use is Energy Stats by Al Priest, it does the maths for you (and a lot, lot more).
https://play.google.com/store/apps/deta ... nergystats and if you’re on iOS you can get it from the App Store at https://apps.apple.com/gb/app/energy-stats/id1644492526
Downloaded.. thank you.
Trying to find a way to view daily energy from solar but can see looking through this forum that it’s another set of calculations! On Energy Stats can I just subtract discharge energy from output energy?
Fox BMS v2
Fox ESS Hybrid Inverter 3.7
Mira HV25 x5
Trina solar panels x8
Ohme Pro EV charger
Skoda Enyaq
Mira HV25 x5
Ohme Pro EV charger
Skoda Enyaq
If you click on the 'Stats' item it will show the various Output, Feed-in, Grid consumption and towards the bottom an Approximations box which has an approximate of the Solare generated today (based on the [charge - discharge - grid import + home load + export] formula)Dad wrote: Tue Nov 28, 2023 1:48 pm Downloaded.. thank you.
Thank you Dave.
That now estimates just 0.300 KWh. Earlier today that box had 0.600KWh in it when the solar was working mid afternoon. Strange that it’s decreased!
Might take a few days to get to grips with this!
Fox BMS v2
Mira HV25 x5
Ohme Pro EV charger
Skoda Enyaq
Mira HV25 x5
Ohme Pro EV charger
Skoda Enyaq
