Foxess data logger no IP adress
Dear all,
My Foxess data logger / dongle lost connection. Nothing was changed on my part, modem, wifi signal,... all worked up until now. The dongle is blinking fast.
When accessing the logger it has no longer an IP adress, but it finds my wifi SSID:
When trying to update the password and saving it says 'failed' or connection time out.
I removed the dongle for 30 seconds, put it back, but stays the same.
I tried giving access to the MAC address of the dongle through the modem, but no succes.
Someone has experienced something similar?
Could it be the dongle is dead?
Best regards,
Cohen
Re: Foxess data logger no IP adress
Helo,
try to disconnect your Wifi Router for a moment.
If you hava a new Thing on the Wifi it can be, that the Router have two devices at one Adress, then isnt good..
Thanks for thinking with me.
But unfortunately, I have tried this option and it didn't produce different results.
