Weird readings since update
Since the last update to the inverter the readings in the app have gone weird. Before the update the daily analysis figures for consumption "added up" ..as pic 1. Since the update they simply don't, pic 2, and today's, pic 3, so far, are distinctly weird. Any thoughts any one ??
FoxESS H1&AC1(G2) 5kW Inverter
10 x TrinaSolar 450w panels
FoxESS EP6 5.76 kWh Battery
Re: Weird readings since update
To my eyes, pic 1 looks spot on. Pic 2 there's a little gap in the numbers. Pic 3 is wild (can you show the power graph below?
I updated my KH7 inverter yesterday, and figures are looking good for past 3 days.
Is pic 3 perhaps telling you that you've used the balance of 3.9kW charging the battery?
H1 5.0 E G2 inverter
EP11 battery
3680W solar 8 panels
I thought that initially, but the battery was charged to 100% overnight, and is now down to 62%, self use, which is about 2 KWh used of 5, but it still shows 0 use from PV & Bat, screenshot at 12.50 today
I think it's just the very unintuitive way it presents things in order to keep self suffiency value right.
From PV and battery seems to stay zero until consumption exceeds from grid. If you look at the pic below with zero from PV and battery, energy stats tells me actual battery discharge that day was 4.1kWh.
The pic with from PV and battery 0.5kWh actually had battery discharge of 4.4kWh.
EP11 battery
