New to all this Solar and Battery stuff could use some advice
Hi guys, been a long time since I joined a forum. :D
Octopus have installed 9 x JA panels and a 5KW battery but i am having problems
charging it.
I suspect due to cold... but its confusing and its limiting the charge to the point I can't cover peak hours.
Charges at 1.7kw till about 40 percent then just drops to 500w
I forced a charge the other night with a 5 hour window to charge after 5 hours it was still sitting in about 50 percent.
Fox EVO 5-3.7-H 5Kw.. 3.68kW Inverter built in. ( fitted outside)
9 x 455w Ja panels
Re: New to all this Solar and Battery stuff could use some advice
Here is a guide on how to filter items in the App, viewtopic.php?p=19593#p19593 this will allow you to find the magical 'Min Cell Temp' entry that determines charge/discharge speeds
Once you can get this information from your system, post up images so they can be analysed
9 x 455w Ja panels
Looks like an emergency charge at 3°C occurred twice, this you can see if you move finger over the chart to find the values at a point in time.
Next is to show work mode if you have setup overnight/cheap off peak charging.
Also, good idea to mention what kit you have, so Inverter model and battery details... some have heaters built in, others don't.
Last item for now, where is the battery fitted... if outside, it will struggle.
9 x 455w Ja panels
I enabled the heater to trigger at 8c and go off and 14C today ( might not have worked in time)
Should this be scheduled to come on and hour before its due to charge?
Does the heater need to be still on the whole time its charging?
Right now its work mode is set to force charge between 2-5AM then go to selfcare.
is there a way I can force it to save a percentage of power for peak hours?
Thank for the replies
9 x 455w Ja panels
This is what I've just done.
anyone see any issues with this?
its meant to charge of a night and self-use in the day but saving 70 percent of the change for the peak and the rest of the night until it changes again at 2am
9 x 455w Ja panels
Heating is a subjective thing, and you have to make choices. Charging the battery generates heat, so to warm it before the cheap period might not be needed. From my own experiments, it should discharge at full rate to at least 8°C (my battery never got colder to test the lower limit) Charging has several bands, at 21°C it's full power, and seems to lower the charge rate every 5°C it drops (I measured 16°C & 11°C, suspect 6°C is another bracket)
Unless this has been fixed, you normally cannot charge and heat at the same time, you can only do one. Remember the charge warms it up, so that's handy.
So you can set the heater to run 24hrs, but with lower temperature limits (4°C to 8/9°C?)
You could run the heater as you say, just before a charge.
Alternatively, just monitor the graphs (now you know where to filter) and make decisions based upon past data, or looking at weather forecast.
And then there's the more savvy thing to do, insulate it! Many members have made a 'box' around it with some king span to keep the temperature more stable.
As for the schedule, best way to learn is to set and check the results. It seems that it should do what you want it to, but choices do depend on the tariff you are on, off-peak vs peak etc.
Thanks for these replies guys, really helped clear things up.
Hopefully, I might be able to get a full charge on this battery tonight with this heater on. :D
9 x 455w Ja panels
Just to update...The Fox Evo 5 heater is really good ... and it holds temp for ages after it hits target.
I have reduced the warm-up time before charging to 40 mins its so quick. (uses 300w)
Charging at 3.6kw right now
Cheers
9 x 455w Ja panels
