I'm a new customer of Intelligent Octopus Go, and therefore have cheap electricity from 2330 through to 0530 overnight.
I used that to charge my EV, and also wanted to charge my home battery using the cheap rate. So I set mode scheduler to forced charge for that period (I had to do two separate intervals to enable it to cross through the midnight barrier). But what happened was that it drained the battery first to charge the EV; then once the battery was drained, it then pushed all the available electric into the EV until the EV had reached its set capacity (50%). At that point, it stopped charging the EV and then started charging the battery.
So the battery was up to 100% this morning, which was fine. But on some occasions, I'll want to charge the car all the way through the cheap charge rate. Which would mean that there's no further time to charge up the home battery if it's drained itself, and I'd start the day on 10% (minimum charge).
Is there a way to set the schedule to allow the home battery to charge only, but not discharge during that period? I can't see an option for this in mode scheduler?
I've attached a pic of the schedule I've set, in case I've done something wrong
You need to adjust the charge session after midnight, so that it HOLDS the battery. What it does now, is charge to 100%, then it swaps work mode to 'Self-use' which then drains house battery to any loads... in your case the car eats it.
Change this red circled value to either 'Backup' or 'Standby' this makes the battery hold the charge until the end of the time period.
Thanks, I really appreciate that advice. I can see how it would make sense if the battery ever started taking charge in the pre-midnight session. But here's the green line chart showing the battery state of charge yesterday, which includes, at the far right, the period from 2330 to 2359. It never started taking charge? So how would I get it to take charge to a point where I could then get it to hold or standby?
If it is not taking a charge, then the battery might be too cold, or your mode scheduler has crashed (so everything needs a restart)
You can use filtering to find the temperature last night viewtopic.php?p=19593#p19593 then you can see if this is a factor or not.
Again, thanks. It looks like the cell temperature was about 10 degrees C (I'm not quite sure which one to pay most attention to), which would usually mean it would charge fine from the PVs. So I'm fairly confident I can rule that out.MaterialBarracuda48 wrote: ↑Fri Nov 27, 2026 11:45 am If it is not taking a charge, then the battery might be too cold, or your mode scheduler has crashed (so everything needs a restart)
So maybe I need to do a reset, although that fills me with fear! I've seen your linked video here so I'll try to see how I might do that. Eek.
'Min Cell Temp' is the boss of things, and decides what charge/discharge rates to apply. At 10.5°C it would have been charging at ~2.5kW or so. Since your scheduler looks fine, then there was something else happening sadly.
Glad you found the video from Will, it will be fine to reboot (1st one is always scary, sadly you have to rip the band aid off)
Might be an idea to nuke the existing schedules, reboot, then recreate if you can see battery/load in App just fine.
Super, thanks for that advice. I'll gird my loins, rip the band-aid off and give it a go!
