Feed-in Priority and Period Min. SOC?
Hi all.
Wondering how the Period Min. SOC works for Feed-in Priority mode. I'm hoping that if SOC drops below the minimum then it goes back to Self-Use and charges the battery. But I'm worried it will go to Back-Up mode or something and conserve SOC, using power from grid instead of discharging the battery.
Does anyone know for sure?
Thanks!
Re: Feed-in Priority and Period Min. SOC?
That's a good question, I don't know for sure, but below is my best guess.
I can only recommend (unless someone answers for definite) that you do a little experiment. If say you SoC is 43% then put the minSoC and maxSoC just below and above. For example 40% and 45%, then sit back and observe what behaviour happens over a few minutes/hours as needed.
I expect that when minSoc is reached, that it swaps back to your 'Global' fallback work mode set in your scheduler. The maxSoC setting, should allow excess PV that is above your export & load to charge the battery as normal, and then once it reaches this value, it's either going to stop charging the battery, or the inverter will change to your fallback work mode.
