Battery discharged overnight. Please explain this!
Would appreciate some help here. I set a force charge to my home battery from midnight to 0200 but this didn't activate. I probably left the 'set charge from grid' setting as disabled by mistake which I've done before. However from 0200 the battery discharged steadily down to its 10% minSOC. Weirdly I cannot see where this has gone - the battery was at 47% at midnight so it has discharged about 5kWh when the app shows only 0.9kWh consumption and no grid export. Car charger was not plugged in.
I did see that there was an app update last night so does this have anything to do with it?
Thanks.
4.20kW Solar PV
10x JA Solar 420W panels
Fox H1 3.68kW Hybrid inverter
Fox 1 x ECS2900-H5 14.4kWh
Zappi 2 Electric Vehicle Charger
Re: Battery discharged overnight. Please explain this!
It won't have been the app update that caused this, but depending on your inverter there has been firmware updates pushed recently that could have broken settings.
Thanks. Everything OK last night with a forced charge so fingers crossed it doesn't happen again.
Still have no idea where the 5KWh disappeared to.....
4.20kW Solar PV
Maybe you have intermittent load left on? a few days ago the battery was steadily discharging much faster, yet load graph on FoxCloud showed nothing. As I have home assistant with 1 second intervals recorded, I could see the home assistant load graph was 'hazy' for several hours, rather than a well defined line. Zooming in I could see a load of 3kW for a few seconds, then it was disappear then a minute later or so would repeat. As it was off far more than it was on, it didn't show on the 5 minute graph. I eventually found the iron ha been left on for hours! I turned it off an everything returned to normal! I can imagine intermittently switching between 3kW and a few hundred watt drains the battery more than a sustained draw as it's starting and stopping all the time over a large range, but maybe not too.
1 x H1-5.0-E-G2-WL Inverter with 5kW G99 DNO export approval
1 x EP12 (W) Battery with heater
8 x Eurener 450W PV panels (3.6kW)
EPS sockets using inverter's internal EPS output
